Date/Time: Sun, 05 May 2024 07:54:45 +0000
AMP/TTnet spread symbols
View Count: 941
[2014-05-20 22:14:38] |
tomas262 - Posts: 135 |
Hello, are futures spreads supported with AMP/TTnet? I used TT FIX before for trading spreads. Now with AMP when I click "get spreads symbols" for CL for example but nothing happens. Thanks |
[2014-05-21 00:36:11] |
This means they are not supported on the server side. They are supported within Sierra Chart.
