Date/Time: Mon, 29 Apr 2024 01:03:47 +0000
Hiding Continuous Horizontal Line In Fill Space
View Count: 1805
[2014-05-20 21:11:01] |
ged - Posts: 233 |
Is there a way to hide a continuous horizontal line in the fill space area (so that it won't visually interfere with text studies that are displayed there)?
[2014-05-21 22:31:23] |
ged - Posts: 233 |
Let me rephrase this question: By way of example, if a horizontal line is plotted by a study, such as Pre-market high or low line, that horizontal line does not intrude into the fill space on the chart. Is there a way, or would you be able to provide a way, for that same functionality to be applied to a horizontal line that I draw on my chart (a way to prevent the line from intruding into the fill space and interfere with text studies that are placed there)? Thanks much. |
[2014-05-21 23:08:14] |
You just need to use the Line drawing tool and draw a horizontal line which ends at a particular point in time.
[2014-05-22 00:17:15] |
ged - Posts: 233 |
I want the line to show up on the following day. If I "extend" a horizontal line, it will intrude into the fill space. If I end the line before the fill space, are you saying that it will automatically extend itself into the future, but not appear in fill spaces?
[2014-05-22 03:20:04] |
No. You do have to manually extend the Line.
