Date/Time: Mon, 29 Apr 2024 03:56:38 +0000
Transition from demo to subscription service.
View Count: 1056
[2014-05-20 17:28:09] |
User26994 - Posts: 32 |
If I decide to take out a subscription after my demo period ends, will I be able to save and transfer all the chartbooks I've built up without having to input them all again. My other question is - I've managed to log into my demo a/c on both a pc and a laptop at the same time ...is it possible to have the same set up on both (chartbooks etc) without having to input the info twice (as I'm doing at present)? Obviously that question is also pertinant for when I take out a subscription. Thanks. |
[2014-05-20 18:16:56] |
Sierra Chart - Max - Posts: 5597 |
1. Yes, your set up will remain the same without having to do anything special. 2. To transfer Sierra Chart settings and data from one computer to another, refer to help topic 15: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html 3. There is no need to create a new account, you can just continue with the account that you have already created. 1. To purchase usage time, select "Help >> Add Usage Credit" on the Sierra Chart software menu or press the "Purchase" button on the Sierra Chart Login window.
You can also go to this page in your browser: https://www.sierrachart.com/usercp.php?page=SCUsageTimePayments Login with your Sierra Chart Account Name and Password. 2. Choose the number Months you wish to pay for and the service Package. 3. Choose one of the payment options. Sierra Chart Support Date Time Of Last Edit: 2014-05-20 19:11:57
[2014-05-20 18:27:56] |
Thanks, Max.
