Date/Time: Wed, 08 May 2024 09:06:32 +0000
DOM partially grayed out
View Count: 1178
[2014-05-20 14:50:40] |
Usam654 - Posts: 1 |
Hello when I click the Target tab in the DOM the Group and Quantity is grayed out. I am on version 1132 and using the Ironbeam data feed. When I use the attached orders I can trade 2 contracts. QTY 2 Target/stop match in green When I try to trade 1 contracts with the attached orders it says QTY 1 Target/Stop no match in red. How do I get Group and Quantity in the Targets tab to work? Please advise. |
[2014-05-20 14:53:57] |
When you have the Targets tab selected on the Trade DOM, provide an image of the Trade Window following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-20 15:09:31
[2014-05-20 15:48:59] |
FR37010905 - Posts: 3 |
http://www.sierrachart.com/image.php?l=1400600861689.png |
[2014-05-20 19:08:38] |
What we needed to see was the Trade DOM. Anyway, we reread the original problem and we understand now what you mean. For the Attached Order controls to become active, you need to select an Attached Order in the list of the Attached Orders on the Targets tab. If you want to trade a quantity of 1, you need to make sure there is no more than one Target order and one Stop order listed in the list of Attached Orders on the Targets tab. Here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-20 19:08:55
[2014-05-20 19:53:17] |
here is snap shot of my dom http://www.sierrachart.com/image.php?l=1400615480297.png |
[2014-05-20 22:45:52] |
This is an image of the chart. And it does not show the Trade Window and it is not set to Chart Trade Mode. Was our response given in post #4 helpful? Or do you still have questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-20 22:46:23
[2014-05-21 11:37:50] |
http://www.sierrachart.com/image.php?l=1400672248690.png |
[2014-05-21 17:54:14] |
If you want to trade a quantity of 1, you need to go to the Targets tab of the Trade Window and select Target 2 and press the Remove button. And select Stop 2 and press the Remove button.
