Date/Time: Fri, 03 May 2024 00:59:59 +0000
Multiple Volume Profiles setup
View Count: 1874
[2013-04-30 01:46:22] |
emp0804 - Posts: 31 |
Hi Support, How can I setup the following compsite volume profiles... Screen shot is from Market Delta. The VP on the far right is fixed from 10/2007 to present day, I have that setup already in SC. The middle is a VP of the last 5 days to present. The left VP is the current day VP. Thanks! Scott |
Multiple VP.jpg / V - Attached On 2013-04-30 01:44:18 UTC - Size: 20.06 KB - 588 views Attachment Deleted. |
[2013-04-30 18:54:44] |
You will need to add 3 Volume by Price studies to the chart. Here are the general instructions: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html You will need to set the Volume Graph Period Type input for each one according to your specifications. You will need to set Allow Side-by-side Volume Profiles on Right Side input for each one to Yes. Refer to the detailed documentation for these settings here: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-30 18:55:34
