Date/Time: Mon, 29 Apr 2024 08:57:26 +0000
show chart grid
View Count: 3694
[2013-03-22 16:58:46] |
User20529 - Posts: 2 |
When I go to either global graph settings or chart graph settings I am not able to adjust chart grid, chart background ect. I am able to adjust colors for chart dom though.
Date Time Of Last Edit: 2013-03-22 16:59:08
[2013-03-22 17:04:23] |
So you want to change the color of the Chart Grid and Background? If so, refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-22 17:14:03] |
I want to but am not able to. as you can see from the attached file I have no "enable" option, thus I am not able to use.
Capture.JPG / V - Attached On 2013-03-22 17:13:00 UTC - Size: 53.48 KB - 809 views |
[2013-03-22 17:24:24] |
The Enable option is not supported with that item in the list. To enable the Chart Grid, refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#grid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
