Date/Time: Fri, 26 Apr 2024 03:11:23 +0000
$tick - delayed data
View Count: 992
[2014-05-20 13:42:25] |
Sam33 - Posts: 12 |
Hi, I have problem with $TICK. Tick doesn´t show me the data OK (very very slowly, for example for 1 minute, I need every second). I use manual replay- Accurate Trading System Back Test Mode. Others symblos (futures - e-mini) as YM,ES,NQ,EMD.. are OK. Samuel |
[2014-05-20 14:29:55] |
Use the symbol File >> Find Symbol >> Market Stats >> TICK-NYSE instead. This will give you tick by tick data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-20 14:51:39] |
Sam33 - Posts: 12 |
Thank you for advice. I find this symbol but I don´t understand, I cannot to download by this TICK-NYSE longer history - max. from 2014-05-06 to today. I need more - for example 180 days. Samuel |
[2014-05-20 14:57:42] |
Refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html The history goes back to 2014-02-04 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-20 15:13:13] |
Sam33 - Posts: 12 |
Thank you! Have a nice day! Samuel |
