Date/Time: Fri, 26 Apr 2024 13:27:47 +0000
Denali Exchange data feed , difference between fees service
View Count: 319
[2022-10-05 13:44:31] |
User423974 - Posts: 18 |
Hello, Concerning the Denali exchange data feed ,difference between the first two subscriptions, "Full CME Group with Market Depth for nonprofessional Trading accounts" & "Full CME Group for nonprofessional Trading accounts", is in market depth , meaning the cumulative delta, order flow and footprint will not work or won't be available ? Thanks |
[2022-10-05 14:30:29] |
John - SC Support - Posts: 31131 |
It means that the Market Depth will not be available if you select the option without Market Depth. The Market Depth shows the waiting Limit orders on the DOM. Cumulative Delta, Order Flow/Footprints/Numbers Bars, will work fine without the Market Depth, as these items are calculated from the actual trades that have taken place, not from the Market Depth information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
