Date/Time: Wed, 08 May 2024 02:31:40 +0000
Stop Order based on Volume
View Count: 1045
[2014-05-20 01:13:54] |
Nestor Dominguez - Posts: 2 |
Hello SC Staff, can you please consider developing a "Volume-Stop" Order feature based on VOLUME. I want the ability to place a protective volume-stop-Order with the ability of setting the volume-threshold-parameter to 500 for example. The idea is to not be taken out of a position because a few contracts breaching my set price point. Can you please employ this option in your software. It would be deeply appreciated. |
[2014-05-20 05:13:54] |
Thib - Posts: 54 |
+1. It would be useful!
[2014-05-21 02:29:50] |
This will be considered. However, it is not likely that we would get to it for some time.
