Date/Time: Fri, 26 Apr 2024 09:00:26 +0000
trade window too small
View Count: 307
[2022-10-04 03:23:59] |
User447693 - Posts: 24 |
The trade window is too small i cannot see all the buttons and I cannot enlarge it like u with other windows it. the size of the windwos is 1 inch by 3 inches i cannot drag and make the size bigger or wider like u show in ur documentation. there is only a x button to close the window https://www.sierrachart.com/image.php?Image=1664853658515.png |
[2022-10-04 15:38:54] |
Sierra_Chart Engineering - Posts: 14092 |
That particular window can only be controlled through the operating system settings. Refer to: Graphics Settings: Adjusting Size of Dialog Windows We are going to reimplement how that window is implemented and not have any dependency upon the operating system. But this is still a ways away. One thing you can do is add Control Bar buttons to replace many of the controls, but not everything: Control Bar The control bar size is fully adjustable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-04 15:39:01
