Date/Time: Wed, 01 May 2024 11:43:35 +0000
number bar study: have the ability to choose the number of tick per volume bar like the volume b
View Count: 851
[2014-05-19 19:39:45] |
User99689 - Posts: 27 |
hello support, It would be interesting to display bid*ask not tick by tick price but for a range of ticks price that user can choose like the option in the volume by price study. Thanks for your answer. |
[2014-05-22 05:19:09] |
This is already supported. You just need to increase the chart Tick Size in Chart >> Chart Settings.
