Date/Time: Fri, 18 Jul 2025 22:59:29 +0000
Stochastic Momentum source code
View Count: 627
[2022-10-01 19:01:41] |
User203192 - Posts: 33 |
Anyone know where to get the Stochastic Momentum source code or at least a relative build on it in C++?
[2022-10-02 08:34:59] |
JohnR - User831573 - Posts: 333 |
You might try here C:\SierraChart\ACS_Source\Studies8.cpp (49 hits) Line 5310: SCSFExport scsf_StochasticMomentumIndicator(SCStudyInterfaceRef sc) Hope this helps, JohnR |
[2022-10-02 17:42:10] |
Nothing does up when I click that into the browser? It brings me to a google search? If I search the ACS_Source folder it comes up as zero in the search. Tried a couple different name tittle as well?
[2022-10-02 17:52:36] |
Ackin - Posts: 1865 |
SCSFExport scsf_StochasticMomentumIndicator(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_SMI = sc.Subgraph[0]; SCSubgraphRef Subgraph_AvgSMI = sc.Subgraph[1]; SCSubgraphRef Subgraph_Overbought = sc.Subgraph[2]; SCSubgraphRef Subgraph_Oversold = sc.Subgraph[3]; SCInputRef Input_OverboughtInput = sc.Input[0]; SCInputRef Input_OversoldInput = sc.Input[1]; SCInputRef Input_PercentDLength = sc.Input[2]; SCInputRef Input_PercentKLength = sc.Input[3]; SCInputRef Input_ExpMovAvgLength = sc.Input[4]; if (sc.SetDefaults) { sc.GraphName = "Stochastic Momentum Indicator"; sc.StudyDescription = "Stochastic Momentum Indicator"; sc.GraphRegion = 1; sc.AutoLoop = 1; Subgraph_SMI.Name = "SMI"; Subgraph_SMI.DrawStyle = DRAWSTYLE_LINE; Subgraph_SMI.PrimaryColor = RGB(0,255,0); Subgraph_SMI.DrawZeros = false; Subgraph_AvgSMI.Name = "SMI Average"; Subgraph_AvgSMI.DrawStyle = DRAWSTYLE_LINE; Subgraph_AvgSMI.PrimaryColor = RGB(255,0,255); Subgraph_AvgSMI.DrawZeros = false; Subgraph_Overbought.Name = "Overbought"; Subgraph_Overbought.DrawStyle = DRAWSTYLE_LINE; Subgraph_Overbought.PrimaryColor = RGB(255,255,0); Subgraph_Overbought.DrawZeros = false; Subgraph_Oversold.Name = "Oversold"; Subgraph_Oversold.DrawStyle = DRAWSTYLE_LINE; Subgraph_Oversold.PrimaryColor = RGB(255,127,0); Subgraph_Oversold.DrawZeros = false; Input_OverboughtInput.Name = "Overbought Value"; Input_OverboughtInput.SetFloat(40.0f); Input_OversoldInput.Name = "Oversold Value"; Input_OversoldInput.SetFloat(-40.0f); Input_PercentDLength.Name = "%D Length"; Input_PercentDLength.SetInt(3); Input_PercentKLength.Name = "%K Length"; Input_PercentKLength.SetInt(5); Input_ExpMovAvgLength.Name = "EMA Length"; Input_ExpMovAvgLength.SetInt(3); return; } sc.DataStartIndex = max(Input_PercentKLength.GetInt(), Input_PercentDLength.GetInt()); if (sc.Index < sc.DataStartIndex) return; SCFloatArrayRef TempLowest = Subgraph_SMI.Arrays[0]; SCFloatArrayRef TempHighest = Subgraph_SMI.Arrays[1]; SCFloatArrayRef TempRelDiff = Subgraph_SMI.Arrays[2]; SCFloatArrayRef TempDiff = Subgraph_SMI.Arrays[3]; SCFloatArrayRef TempAvgRelMA = Subgraph_SMI.Arrays[4]; SCFloatArrayRef TempAvgRel = Subgraph_SMI.Arrays[5]; SCFloatArrayRef TempAvgDiffMA = Subgraph_SMI.Arrays[6]; SCFloatArrayRef TempAvgDiff = Subgraph_SMI.Arrays[7]; sc.Lowest(sc.Low, TempLowest, Input_PercentKLength.GetInt()); sc.Highest(sc.High, TempHighest, Input_PercentKLength.GetInt()); TempRelDiff[sc.Index] = sc.Close[sc.Index] - (TempHighest[sc.Index] + TempLowest[sc.Index]) / 2.0f; TempDiff[sc.Index] = TempHighest[sc.Index] - TempLowest[sc.Index]; sc.ExponentialMovAvg(TempRelDiff, TempAvgRelMA, Input_PercentDLength.GetInt()); sc.ExponentialMovAvg(TempAvgRelMA, TempAvgRel, Input_PercentDLength.GetInt()); sc.ExponentialMovAvg(TempDiff, TempAvgDiffMA, Input_PercentDLength.GetInt()); sc.ExponentialMovAvg(TempAvgDiffMA, TempAvgDiff, Input_PercentDLength.GetInt()); if (TempAvgDiff[sc.Index] != 0.0f) Subgraph_SMI[sc.Index] = TempAvgRel[sc.Index] / (TempAvgDiff[sc.Index] / 2.0f) * 100.0f; else Subgraph_SMI[sc.Index] = 0.0f; sc.ExponentialMovAvg(Subgraph_SMI, Subgraph_AvgSMI, Input_ExpMovAvgLength.GetInt()); Subgraph_Overbought[sc.Index] = Input_OverboughtInput.GetFloat(); Subgraph_Oversold[sc.Index] = Input_OversoldInput.GetFloat(); } |
[2022-10-02 17:55:23] |
Thank you!!
[2022-10-02 23:36:29] |
Sierra_Chart Engineering - Posts: 20254 |
For further information, refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-02 23:50:17
