Date/Time: Fri, 27 Jan 2023 13:57:37 +0000
Using Subgraph.DataColor to change background color in ACSIL
View Count: 131
[2022-10-01 07:28:51] |
User29662 - Posts: 76 |
Sierra Chart Documentation states that: "An ACSIL (Advanced Custom Study Interface and Language) study can optionally use the sc.Subgraph[].DataColor array to use alternate coloring for the background at each chart column that differs from the primary color." Are there any examples out there of how this would be coded? |
[2022-10-02 18:00:09] |
Ackin - Posts: 1845 |
...\SierraChart\ACS_Source\studies8.cpp SCSFExport scsf_BackgroundDrawStyleExample(SCStudyInterfaceRef sc) { SCSubgraphRef Subgraph_Background = sc.Subgraph[0]; SCSubgraphRef Subgraph_BackgroundDC = sc.Subgraph[1]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Background DrawStyle Example"; sc.StudyDescription = "Background DrawStyle Example"; sc.AutoLoop = true; sc.GraphRegion = 0; sc.DrawStudyUnderneathMainPriceGraph = 1; // not required in studies, but want color behind price for this study Subgraph_Background.Name = "Background"; Subgraph_Background.DrawStyle = DRAWSTYLE_BACKGROUND; Subgraph_Background.PrimaryColor = COLOR_LIGHTGREEN; Subgraph_Background.SecondaryColor = COLOR_LIGHTPINK; Subgraph_Background.SecondaryColorUsed = true; // turn on if both colors are to be used Subgraph_Background.AutoColoring = AUTOCOLOR_POSNEG; // use positive/negative values to signify colors Subgraph_BackgroundDC.Name = "Background DataColor"; Subgraph_BackgroundDC.DrawStyle = DRAWSTYLE_BACKGROUND; Subgraph_BackgroundDC.PrimaryColor = RGB(255,0,255); return; } // Do data processing int min = sc.BaseDateTimeIn[sc.Index].GetMinute(); if (min > 0 && min < 15) Subgraph_Background[sc.Index] = 0; // do not color background else if (min >= 15 && min < 30) Subgraph_Background[sc.Index] = 1; // use primary color else if (min >= 30 && min < 45) Subgraph_Background[sc.Index] = -1; // use secondary color else if (min >= 45 && min < 60) { Subgraph_BackgroundDC[sc.Index] = 1; Subgraph_BackgroundDC.DataColor[sc.Index] = RGB(0, 0, 17*(60-min)); } } |
[2022-10-02 18:43:15] |
Sierra_Chart Engineering - Posts: 6328 |
This would only work, if you set the Draw Style for that Subgraph to Background as is given in the example in the prior post.: Subgraph_Background.DrawStyle = DRAWSTYLE_BACKGROUND; More information: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scSubgraph.html#scSubgraphDrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-02 18:43:25
