Date/Time: Thu, 08 Oct 2026 03:47:53 +0000
Empty space on chart
View Count: 1982
[2022-09-30 10:23:39]
User266447 - Posts: 280
One of my charts has a lot of empty space between the price scale and the graph. I do not know how to narrow the empty space. Usually, you have candles almost right to the scale, but on this (volume chart) I have candles far away from the scale. If I do right-click on the scale and use Set X & Y constant relation or anything else from the menu (i.e.scale range) it does not work. If I bring the candles very close to the price scale the chart is unreadable. Please help. I can attach the chart setup if you wish - just tell me. Meantime please see the print screen.
image2022-09-30 11_13_02-Window.png / V - Attached On 2022-09-30 10:23:15 UTC - Size: 19.02 KB - 509 views
[2022-09-30 10:32:53]
Ackin - Posts: 1865
check this:
Working With Charts: Right Side Fill Space
Working With Charts: Removing Right Side Fill Space
