Date/Time: Thu, 02 May 2024 13:42:16 +0000
up/down tick chart and kase bar
View Count: 336
[2022-09-29 22:09:26] |
User887126 - Posts: 60 |
Hello SC support board, Is there a single custom study to show up/down tick chart? i did see a post about using study collection but was wondering if there is an easier and simpler study available at this point. Also, is there a kase bar available for sierra chart? Thank you for your time. |
[2022-10-02 18:46:19] |
Sierra_Chart Engineering - Posts: 14176 |
We are not sure what this is: Is there a single custom study to show up/down tick chart?
However, refer to:UpTick Volume DownTick Volume We did a quick search for Kase bars and these are a type of Range bar. Sierra Chart has six different types of range bars which are documented here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu) You should find one that meets your requirements. Also refer to: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
