Date/Time: Mon, 29 Apr 2024 03:46:06 +0000
DOM orders getting filled when price not even close
View Count: 372
[2022-09-29 14:06:48] |
User449884 - Posts: 136 |
My orders, are getting filled with price being 1-2 ticks away. Is this a settings issue?
[2022-09-29 14:25:52] |
Sierra_Chart Engineering - Posts: 14126 |
First make sure you are not getting delayed data. Go to Window >> Current Quote Window and check the timestamp of the data and make sure it is current. Make sure your computer's clock is set to the current time.
[2022-09-29 15:57:21] |
Yes all his synced. orders are still getting filled when the prices is not even at that price.
[2022-09-29 17:53:05] |
Is this with live trading?
[2022-09-30 14:41:48] |
Yes
[2022-09-30 14:58:03] |
Are you using limit orders or market orders?
[2022-09-30 16:02:18] |
using stop limit orders
[2022-10-02 18:45:04] |
If you want to make sure that Stop-Limit order does not fill any different than the Stop price, then set the Limit Offset to 0: Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
