Date/Time: Fri, 26 Apr 2024 01:19:42 +0000
Equity symbols
View Count: 281
[2022-09-28 21:03:28] |
User262131 - Posts: 5 |
Hi, With the NASDAQ total view, is there any way I can get the ticker into a chart by just typing the symbol, ie. TSLA instead of TSLA-NQTV? Like make nasdaq the default? When I type normal ticker it brings up the delayed data. Thanks, Brian |
[2022-09-28 21:35:42] |
John - SC Support - Posts: 31131 |
There is not. When you do not use the -NQTV suffix, that is telling our system to get data from our Sierra Chart Exchange Data Feed, which does not have any Market Depth Data and will be going away soon. Therefore, you need to continue to use the -NQTV for the equities. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
