Date/Time: Thu, 11 Jun 2026 19:56:31 +0000
[Programming Help] - missing signal
View Count: 980
[2022-09-28 17:21:56]
User411320 - Posts: 376
attached is a htf chart showing the rsi cross and ltf chart that colors candles based off it. there should be a yellow where i circled in white (15:15:32-15:15:35). I get 2 purples, it's suppose to be cyclical so a yellow is missing
Private File
Private File
[2022-09-28 20:58:30]
John - SC Support - Posts: 46644
This is not something we can help with. There is something about your formula that is not giving you what you want, or you are not using it in a way that you can get what you want.
You need to look at your information and determine where the issue lies.
[2022-09-29 17:24:26]
these are the formulas I wrote using the "color bar based on alert condition"
=CROSSFROMBELOW(ID3.SG1,ID3.SG4)
=CROSSFROMABOVE(ID3.SG1,ID3.SG4)
with that being said, the RSI I'm using is from SC.
[2022-09-29 18:03:32]
The formulas themselves are fine. Are you using 2 different Color Bar Based on Alert Condition studies, one for the Cross from Below and the other for the Cross from Above?
[2022-09-30 18:54:00]
yes I'm using 2 exactly as you said
[2022-09-30 20:06:15]
If you can get us the chartbook that contains the charts then we can take a look and see what is going on. Refer to the following to attach a file:
[2022-09-30 21:31:41]
attached is the chartbook. Hope I did it correctly thanks
Private File
[2022-09-30 21:47:49]
It is working fine for us. The image at the following link is what we see:
https://www.sierrachart.com/image.php?Image=1664574315404.png
You can see two yellow bars, one at 14:02:36 and the other at 14:21:54. These correspond to when the RSI crosses the RSI Average from above, as per your Color Bar Based on Alert Condition.
[2022-10-04 20:43:28]
thank you
