Date/Time: Fri, 27 Jan 2023 14:27:24 +0000
synchronized between computers via the internet
View Count: 120
[2022-09-28 16:00:27] |
Hopeman - Posts: 92 |
Hello! Sierra chart is synchronized between computers via the internet, this causes me a problem since I need different configurations depending on the computer I am using, do you know if this option can be deactivated. Thanks |
[2022-09-28 17:46:40] |
John - SC Support - Posts: 21711 |
The only option that we have available is to share chartbooks and files through our file download system. But we looked at your account and you are not set to have any files downloaded. Therefore we have no idea what you mean by "Sierra Chart is synchronized between computers via the internet...". We do not know if we can help you further, as this sounds like some kind of personal setup, but if you want to give us some information on what you have setup, we might be able to help. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-10 18:37:23] |
It was my mistake sorry for the inconvenience and thank you for your attention and patience
