Date/Time: Fri, 27 Jan 2023 13:40:25 +0000
Draw Volume profile
View Count: 140
[2022-09-28 15:14:29] |
rikki - Posts: 6 |
Good morning, Unfortunately I cannot find the way to draw the volume profile on the right side, next to the price ladder in the chart basically. I would like the profile to show values on its left. Hope that is clear and hope it is useful for the community Thanks |
[2022-09-28 17:19:49] |
John - SC Support - Posts: 21711 |
We are not sure if you are asking specifically for the "Drawn Volume Profile" tool, or just in general for putting a VbP to the right side of the graphics area (next to the price ladder). But, the general rule is the same for both. In particular, when adding a VbP, you would want to set the following two Inputs for the Study to Yes: - Right Align Volume Bars - Align to Far Right To get the Volume information for each bar to display to the left side of the profile, set the following Inputs for the study: - Display Volume in Bars: Set to the value you want to display - Align Volume Numbers to Base Of Volume Bars: No ----- If you are setting up the Drawn Volume Profile, you will set the items up above and then save these settings as a Study Collection. Then use that Study Collection in the Drawn Volume Profile Configuration. Refer to the following: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
