Date/Time: Sat, 04 May 2024 23:58:33 +0000
[User Discussion] - fib bands/horizontal areas color
View Count: 988
[2014-05-19 12:19:08] |
jimnovak - Posts: 42 |
hi i need to draw horizontal lines and then color the area between them. for instance at the moment i use fib tool starting at a high pivot of a certain chart and go to a low pivot. the fib lines displayed are 0,33,67,100.(so the area is divided to three equal parts)but instead of lines i like those areas be colored in different colors so i can spot them easily. can you help? is there a tool that does that? regards |
[2014-05-20 14:44:15] |
How about using the Tools >> Rectangle tool and highlight each area separately. The interior of the rectangle can be filled and can be transparent. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-20 14:44:30
[2014-05-20 14:50:58] |
no that wont do it.i ve tried it though. first id have to use fib tool to determine the appropraite 1/3's. then if i do rectangle over them, it only extends to where the last bar is(or just after), doesnt continue as more bars are added.in other words it's static. |
