Date/Time: Fri, 26 Apr 2024 03:33:08 +0000
Does sc.ServerConnectionState not work in delayed data feed?
View Count: 317
[2022-09-26 16:12:42] |
antayawat - Posts: 3 |
As the title suggested, I am using delayed data feed service and "sc.ServerConnectionState" does not seem to work. The only way I can make it work is to press Disconnect manually. Even when I disconnect my internet entirely, it still doesn't work. The chart just stops updating and nothing happens. Is this normal behavior? For reference, a part of my program consists of code exactly like in below link. ACSIL sc.ServerConnectionState behavior |
[2022-09-26 17:11:46] |
Sierra_Chart Engineering - Posts: 14092 |
Yes what you describe does make sense because of how the connection is made. It is what we call a sub data service connection for market data in the background. The state of the connection cannot be detected through that variable.
[2022-10-01 13:07:29] |
User61576 - Posts: 418 |
Is there any other variable to detect the status of sc feed?
[2022-10-01 20:18:40] |
User90125 - Posts: 715 |
See this thread: loss connexion
[2022-10-02 01:08:34] |
No there is not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-02 01:08:40
