Date/Time: Fri, 27 Jan 2023 15:07:12 +0000
Replay all the charts in all the instances
View Count: 125
[2022-09-24 20:52:48] |
User887126 - Posts: 43 |
Hi, I have several charts for the same symbol across 3 instances. What is the best way to replay all the charts in all the instances simultaneously. I know i can just add all the charts to one instance and replay all the charts. The issue is i want to spread them out across 3 different instances for performance reason and to work with multiple monitors setup. Thank you in advance. |
[2022-09-25 14:45:42] |
Sierra_Chart Engineering - Posts: 6328 |
There is no way within Sierra Chart to accomplish this automatically. Maybe you could do something with ACSIL since ACSIL does have full control over chart replays now.
[2022-09-26 12:53:20] |
JohnR - User831573 - Posts: 231 |
You should be able to accomplish this using autohotkey and create a macro that starts all three instances. You could also create other macros that pause, etc. Hope this helps, JohnR |
