Date/Time: Mon, 02 Nov 2026 07:41:38 +0000
Connection between SC and LMAX does not function anymore
View Count: 763
[2022-09-24 09:41:03]
User418920 - Posts: 31
Good morning,
I have recently setup a 2nd SC instance and connected that instance to IB.
My first instance (the original) is connected to LMAX.
Now the 2nd instance is connected to IB and is up and running, it seems that my first instance that is connected to LMAX does not work anymore. The data connection cannot be made anymore. It says: "reconnect Wait", see attached screenshot. I have done a delete and download all data, and checked that the data/trade services setting are set to <LMAX Live trading.
What do I have to do in order to have both instances (IB as well as LMAX) working?
Kind regards, Thomas
imageSchermafbeelding 2022-09-24 om 11.36.29.png / V - Attached On 2022-09-24 09:39:16 UTC - Size: 10.73 KB - 311 views
[2022-09-24 10:28:04]
Sierra_Chart Engineering - Posts: 25344
For the instance that you are connecting to LMAX:
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2022-09-24 13:35:03]
I have just sent the message log via the "send for analysis" option in SC
[2022-09-24 16:12:38]
This is the problem:
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2022-09-24 15:32:43.700 *
This must be caused by a firewall on your computer. Refer to help topic 1.2:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
We can successfully connect:
LMAX Live Trading - DTC | Connecting to the server lmaxtrade2.sierracharts.com. Port 11096 | 2022-09-24 12:11:20.442
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2022-09-24 12:11:20.516
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-09-24 12:11:20.516
DTC Client socket (3) | Connecting to IP: 51.89.152.221. | 2022-09-24 12:11:20.516
LMAX Live Trading - DTC | Network connection to server complete. | 2022-09-24 12:11:20.555
LMAX Live Trading - DTC | Starting socket receive thread. | 2022-09-24 12:11:20.555
LMAX Live Trading - DTC | Sending encoding request to server: Binary VLS. Compression: none | 2022-09-24 12:11:20.555
LMAX Live Trading - DTC | Setting DTC encoding to Binary VLS | 2022-09-24 12:11:20.668
LMAX Live Trading - DTC | Sending logon request message. | 2022-09-24 12:11:20.668
LMAX Live Trading - DTC | Received logon response. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Server Name: SC DTC Server. Build=42846. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Successfully connected. Connected to SC DTC Protocol server. Service=lmaxtrading|SymbolSettings=lmax_server.exchange.trading. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Trading is supported. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Order cancel and replace is supported. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | OCO Orders supported. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Bracket Orders supported. | 2022-09-24 12:11:20.706
LMAX Live Trading - DTC | Connected to server complete. | 2022-09-24 12:11:20.706
Date Time Of Last Edit: 2022-09-24 16:13:39
