Date/Time: Mon, 02 Nov 2026 07:41:40 +0000
Change Font Color on Numbers Bars Column 2
View Count: 1331
[2022-09-23 17:43:24]
Sousa - Posts: 7
How do I change the font color in column two of the Numbers Bars study without changing the color of the background type?
I've attached a screenshot & circled the numbers I am referring to.
Additionally, how can I bring those numbers to the front, so they are not behind the background type?
Thank you.
imageFootprint Chart.png / V - Attached On 2022-09-23 17:42:53 UTC - Size: 72.35 KB - 234 views
[2022-09-23 20:54:13]
In order to have different colors for the numbers from the background, refer to the information for this Input on the Numbers Bars study:
Numbers Bars: Use Separate Colors for Text Coloring Method
Note that this will affect all columns.
Also, the numbers are drawn above the background, but since you have the same colors, you can not see this right now.
