Date/Time: Sat, 27 Apr 2024 04:07:33 +0000
How do i get the scale right hand scale to show extact numbers
View Count: 240
[2022-09-23 12:47:43] |
User881831 - Posts: 6 |
See the picture attached. For the VolumeByPrice study, I have it to extend the POCs but it is all even or .25 increments. The current price label shows it at .59 I want the POCs and all those variables to show the exact .xx number not in .25 .50 .75 1.00 increments. Please let me know thank you. |
Screen Shot 2022-09-22 at 7.31.36 PM.png / V - Attached On 2022-09-23 12:47:10 UTC - Size: 47.26 KB - 68 views |
[2022-09-23 15:35:56] |
What is the symbol for that chart and what is the Chart >> Chart Settings >> Symbol >> Tick Size set to?
[2022-09-24 17:32:16] |
Set to tick size 0.010000 and still showing 134.00 or 143.52 instead of being .54 or .36 .... I am using volume by price daily profile... |
[2022-09-26 13:56:45] |
On the Volume by Price study, make sure the Value Format is set to Inherited. Also check the Ticks per Volume Bar, which will have an impact on the price levels for the items in the Volume by Price. If you want .01 increments, then you would want this to be set to to 1. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
