Date/Time: Mon, 02 Nov 2026 07:40:53 +0000
Australian user having issues with Time zone to get accurate Y Axis time information
View Count: 592
| [2022-09-23 05:31:34] |
| User132988 - Posts: 13 |
Hi All, Im based in Australia and so whilst the support documents mention you must change your PC time zone, I cannot do this because that would break alot of other things. I'm wanting the Y Axis time information for Futures trading but despite subscribing and deleting and redownloading the data, I'm still seeing the incorrect time in the charts (see screenshot) Time in NY should be 1.29am but the chart is showing 9.29 Thanks! |
| Attachment Deleted. |
| [2022-09-23 09:16:21] |
| Sierra_Chart Engineering - Posts: 25344 |
No, the documentation does not say this anywhere: so whilst the support documents mention you must change your PC time zone
Since this is a US futures market you need to set the time zone for the chart itself, to US Eastern: Time Zone Setting: Using Different Time Zone in Individual Charts And make sure the Session Times are still set correctly after: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
