Date/Time: Sun, 05 May 2024 15:37:48 +0000
Spreadsheet colums with data but without title
View Count: 909
[2014-05-18 17:21:42] |
BataviaTrader - Posts: 63 |
Please find attached a print-screen of my spreadsheet. I am having a hard time figuring out what data goes with which indicator, as there are columns without title. Could you advice me? Thank you in advance. |
[2014-05-18 19:09:26] |
Sawtooth - Posts: 3993 |
If there is no title in row 2, the data in that column is left over from adding, removing, or rearranging studies in the Studies to Graph list. Highlight those columns and press the DEL key.
[2014-05-18 21:51:49] |
The answer given in post #2 is correct. Columns without a Subgraph title, are not currently being outputted. Highlight those columns and delete them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-12 18:46:29] |
It has been a while, but now I am giving spreadsheets a new try. I did exactly what you said. However, the numbers in the columns I deleted appear again after 2-3 seconds. I am on version 1173. Please advice, thank you. Date Time Of Last Edit: 2014-08-12 18:47:22
[2014-08-12 22:27:11] |
Attach an image of the spreadsheet so we can understand what you are seeing. Here are the instructions to attach a file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-12 22:27:51
