Date/Time: Sat, 18 May 2024 10:08:57 +0000
connecting to my broker
View Count: 1303
[2014-05-18 13:56:00] |
User55865 - Posts: 7 |
Hi I have changed my charting system from Ninja trader to sierra chart, and also using data from sierra. The problem that I have is my broker is (Mirus/dorman) and I am wandering that, should I change my broker or I can connect my Mirus account to sierra? thanks |
[2014-05-18 20:07:03] |
Sierra Chart does support Mirus/dorman. We just need to know what backend trading platform service you will be using through them. Would it be CTS T4 or CQG? Or something else.
