Date/Time: Fri, 26 Apr 2024 21:28:28 +0000
Data missing
View Count: 589
[2022-09-20 11:41:22] |
User285128 - Posts: 6 |
Hi After downloading the current version, when pc is put on sleep, all data from the point of sleep to wake is lost. Appears as a gap on chart. Fill all gaps simply puts a single straight line bar for time charts and uniform renko bars for renko. Delete/download does not fix. Is this IB feed issue that fixes with Denali or? |
[2022-09-20 16:16:35] |
It could be a data feed issue, but our records are showing that you are connecting to our Sierra Chart data, therefore you should not be having an issue with back-filling, at least not for CME Group data, for which you are setup to get the real-time data from us. What is the symbol of the chart for which you are having issues? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 17:01:09] |
I only went to the sc data today for major exchanges after the issue(been using long time for bitmex data). Set up everything for Denali and the issue is fixed. Thanks.
[2022-09-23 13:16:51] |
Sierra_Chart Engineering - Posts: 14106 |
This is good.
