Date/Time: Sat, 18 May 2024 08:23:27 +0000
Bug in the UseRelativeValue for UseTool
View Count: 877
[2014-05-17 10:49:20] |
sampater - Posts: 243 |
There is a bug in the UseRelativeValue for sc.UseTool, when is used DrawingType = DRAWING_MARKER. If UseRelativeValue is set to 1, then BeginValue is not a relative value, but still as absolute values. E.g., if the BeginValue is set to 2, then the Drawing Marker (tested by MARKER_POINT) is drawing far beyond the area of ​​visibility of the main price graph, and should be drawing the bottom side of the chart. The UseRelativeValue works properly if we use DrawingType = DRAWING_TEXT. (in version 1137) |
[2014-05-17 21:00:11] |
We will check on this.
[2014-05-17 21:08:24] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1140.
