Date/Time: Sat, 18 May 2024 12:27:09 +0000
Bug on Sierra
View Count: 1011
[2014-05-17 08:22:22] |
User78745 - Posts: 38 |
Dear all, Since yesterday evening, I can 't be able to run Sierra Chart. When I do, Sierra Chart Bug. The only solution to close Sierra it s (Ctrl+alt+sup). Anyone get this problem before ? Regards, |
[2014-05-17 10:30:02] |
Refer to help topic 17 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html If you have a Chartbook which is opening automatically and causing an abnormal shutdown, then you need to prevent it from opening automatically. This is explained in section 30.16 here: https://www.sierrachart.com/index.php?l=doc/helpdetails30.html#h30.16 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-17 11:03:09] |
Thank you, Problem solved. It was a study which caused the bug. Regards, |
[2014-05-17 20:54:42] |
Let us know specifically what study you had trouble with if it is one of the User Contributed Studies or if it is a built-in Sierra Chart study. We need to understand why this is happening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-17 20:55:09
