Date/Time: Mon, 02 Nov 2026 08:32:41 +0000
large traders
View Count: 1490
| [2022-09-18 19:53:38] |
| User259724 - Posts: 43 |
Hello: Is there a setting in numbers bars charts to show large block trades? For instance, in the emini SP500, if I want to see large trades of, for example, 100 lot trades or larger on either the bid or ask side is there a setting to show that at the price level it happened on the numbers bar chart? Date Time Of Last Edit: 2022-09-18 20:05:15
| [2022-09-19 13:58:29] |
| Sierra_Chart Engineering - Posts: 25347 |
Refer to Volume Filtering here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-19 16:07:37] |
Also refer to: Numbers Bars: Volume Filtering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
