Date/Time: Sun, 28 Apr 2024 13:21:35 +0000
Using Sierra Chart Data Feed with Amp/TTnet
View Count: 971
[2014-05-16 16:48:35] |
AC95726 - Posts: 2 |
I was told today by AMP/TTnet Technical Support that I can ONLY use TT or Rythmic Data Feed with SC Carting. I asked them straight out if I could use Sierra Chart Data Feed, and was told no. On previous posts I've read I see your answers saying that I can switch to SC Data Feed using my current AMP/TTnet setup. This is totally confusing....Does anyone know the correct answer? If I can use SC Data Feed with AMP/TTnet, then how do I set that up?? Thank You |
[2014-05-16 16:59:38] |
You can only use the Sierra Chart Real-time and Historical Exchange Data Feed, if you have a direct Sierra Chart account. Refer to the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
