Date/Time: Fri, 03 May 2024 13:04:13 +0000
Data Display Question
View Count: 889
[2014-05-16 11:49:05] |
infpz - Posts: 826 |
Does anyone have a suggestion for something like this? I would like to display the previous bar AND current bar high/low on the chart in text format. |
[2014-05-16 13:25:14] |
crazybears - Posts: 314 |
Hi with ACSIL would be far more easy but you could try with 2 istance of previous bar close and range bar predictor all set with Draw Style to Text and value label option selected. |
[2014-05-16 13:31:49] |
Sawtooth - Posts: 3992 |
Here's another way: Two instances of the Previous Bar Close study, one set for H and one for L, and 4 instances of the Text Display For Study study, for the H/L of the previous and current bars. |
[2014-05-16 16:56:40] |
Really you just need to use only the Text Display For Study study. And then you can reference prior bars with the Subgraph Columns Back input. You want to set it to 1 to reference the prior bar.
