Date/Time: Mon, 05 Oct 2026 13:43:29 +0000
Sierra Charts and Level 2.
View Count: 4952
[2022-09-14 03:14:20]
gondolaebin1984 - Posts: 5
Hi I am new to Sierra Charts and I am wondering if there is traditional Level 2 for sierra charts.
Im tinkering around and I opened Market Depth for my chart. And it looks nothing like traditional level 2. And there is no way to change the settings on that Market Depth either.
I heard that the data for Stocks is limited because it is only 40$. I wouldnt mind paying a bit more for better stock data.
imageOKK.png / V - Attached On 2022-09-14 03:11:17 UTC - Size: 69.05 KB - 765 views
imagedsqqdq.PNG / V - Attached On 2022-09-14 03:11:23 UTC - Size: 14.82 KB - 890 views
[2022-09-14 03:23:48]
Sierra_Chart Engineering - Posts: 25060
You need to use the NASDAQ TotalView data.
So the symbol needs to be CMRA-NQTV. Refer to:
Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes
There is not a typical level 2 display but there is a market depth display.
Date Time Of Last Edit: 2022-09-14 03:24:06
[2024-09-09 21:49:35]
User482544 - Posts: 1
Hi All
Getting bit confused. Need Sierra service level 11 package with level 2 DOM with confirmed orders. How much is it altogether? I need DOM in depth one not just the bid and ask the actual confirmed bids.
Does Denali exchange come with this? I would like access the futures and US equties
What are the charges can some one break it down for beginner on Sierra.
thanks
[2024-09-09 23:01:22]
John - SC Support - Posts: 48095
We do not understand what you mean by "level 2 DOM with confirmed orders. How much is it altogether? I need DOM in depth one not just the bid and ask the actual confirmed bids."
Are you referring to the Market Depth data or the actual trades at the bid and ask or something else?
Although, with regards to the Market Depth and the actual trades, the data from our Denali Exchange Data Feed is correct with the Bid/Ask trades stored at every trade, so it is perfectly correct.
What are the futures data you are wanting?
