Date/Time: Fri, 27 Jan 2023 15:39:02 +0000
Entering Stop Trade Volume Triggered from Trading DOM
View Count: 113
[2022-09-13 18:28:06] |
User392433 - Posts: 10 |
Is there a way to enter a stop trade volume triggered order from the trading DOM by clicking on a price? Right now, it seems I have to change the price via a dropdown in the trade window. Also, what happens if I enter a trade volume triggered stop along with a regular stop when I have cancel on flat position on. Is there a scenario where the market stop gets triggered along with the triggered stop because it did not cancel in time? How do I set two attached stops? One being the trade volume and the other being an emergency stop? |
[2022-09-27 09:46:52] |
Sierra_Chart Engineering - Posts: 6333 |
Is there a way to enter a stop trade volume triggered order from the trading DOM by clicking on a price? No this is not supported.Yes this certainly can happen: Also, what happens if I enter a trade volume triggered stop along with a regular stop when I have cancel on flat position on. Is there a scenario where the market stop gets triggered along with the triggered stop because it did not cancel in time?
How do I set two attached stops? One being the trade volume and the other being an emergency stop? You would use Attached Orders:Attached Orders: Step-By-Step Instructions The Volume Triggered Stop will be the parent order and then you would use a single Stop Attached Order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
