Date/Time: Wed, 08 May 2024 07:59:02 +0000
AMP traiding, please, need "amp" service menu.
View Count: 1263
[2014-05-15 19:11:58] |
AC96354 - Posts: 15 |
Go to Sierra Chart. Select Global Settings >> Data/Trade Service Settings on the menu. Click on the Service list box at the top of the window. Select the AMP/TTNet service name from the list. If you do not see this service listed in the list box, then refer to help topic 52. i do not see this service listed in the list box, what i need to do? |
[2014-05-15 19:22:24] |
You are running an older version of Sierra Chart. Update Sierra Chart with Help >> Download Current Version.
[2014-05-16 14:38:41] |
i did all instructions http://www.sierrachart.com/index.php?l=doc/AMPTTNet.php and now i get this error: AMP/TTNet: Connecting. | 2014-05-16 09:30:09 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2014-05-16 09:30:09 The network socket is connected. | 2014-05-16 09:30:09 TT FIX Data: Sending the Logon message. | 2014-05-16 09:30:09 TT FIX Data: Received a FIX message missing required field TargetCompID <56>. | 2014-05-16 09:30:09 FIX Message: 8=FIX.4.2 9=00181 35=5 49=TT_PRICE 34=1 52=20140516-09:30:13.452 58=Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. 18000=1 10=002 | 2014-05-16 09:30:09 TT FIX Data: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. | 2014-05-16 09:30:09 TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2014-05-16 09:30:09 Socket has been shutdown and closed. | 2014-05-16 09:30:09 TT FIX Data: Logged out and disconnected. | 2014-05-16 09:30:09 Disconnected from TT FIX Price Feed session. | 2014-05-16 09:30:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-16 09:30:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-16 09:30:09 AMP/TTNet: Disconnected. | 2014-05-16 09:30:09 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-16 09:30:09 |
[2014-05-16 16:09:49] |
Contact your trading service and let them know you are receiving this message: TT FIX Data: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: is not authorized to use FIX Adapter.. Please contact your System Administrator. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
