Date/Time: Mon, 02 Nov 2026 09:18:58 +0000
graphing selected time based bars into tick based bars ?
View Count: 1159
| [2022-09-11 03:22:30] |
| User180745 - Posts: 12 |
Hi Is there way to select number of bars from time based charts and graph tick bars ? Basically I want to able to select few time based bars (like volume profile drawing tool) and for those selected bars, plot tick charts. Thanks |
| [2022-09-12 13:56:36] |
| John - SC Support - Posts: 48377 |
If you are wanting to see a different period within a single chart, then this is not possible. You can have another chart with Tick Bars and set the Session Times to only show between the specific times you are wanting. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
