Date/Time: Sun, 28 Apr 2024 07:53:27 +0000
ChartDOM
View Count: 1867
[2013-04-29 14:51:39] |
User76676 - Posts: 7 |
How do I create my own bracket orders? If I want the stop to be at 8 ticks and the limit/target to be at 15ticks instead of the default 8ticks for both. Is it possible to get rid of the window where you have to confirm with YES or NO if you want to modify your stop/limit order? If it's possible, how do I do it? Thanks a lot. |
[2013-04-29 17:05:56] |
Bracket Orders are called Attached Orders in Sierra Chart. They are documented here: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html To disable order confirmations you need to disable Confirm Order Modifications on the Trade Window. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-29 17:06:44
