Date/Time: Sun, 19 May 2024 03:36:43 +0000
Why isn't SC carrying any CRB data anymore?
View Count: 1526
[2014-05-15 12:58:29] |
auggie - Posts: 45 |
I am subscribed to SC Data but am not getting any feeds for the CRB index anymore? Thanks, Larry |
[2014-05-15 16:40:15] |
We are not sure. We use an outside data provider for the historical data. You need to find alternative index for that. Refer to this page: https://www.sierrachart.com/index.php?l=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices Search for the word "commodity". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-15 17:20:52] |
Thank you for replying. Can you look into this for us? Not carrying the CRB index for commodity traders is akin to not carrying the DJIA for stock traders... because of the 50 years of historical data that we already have. Thank you, Larry |
[2014-05-15 22:37:24] |
The answer: No, Reuters no longer allow distribution of this Index.
We suggest customers us $GNX - S&P GSCI Commodity Index on the S&P Indices feed as a replacement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
