Date/Time: Sun, 19 May 2024 00:29:30 +0000
[User Discussion] - How do I get (High+Low)/2 Stochastic
View Count: 1571
[2014-05-15 09:04:24] |
User40520 - Posts: 62 |
Can someone please give clear instructions for a simpleton to follow please?
[2014-05-15 15:16:47] |
vegasfoster - Posts: 444 |
Stochastics analyzes the high and low components separately, see http://www.investopedia.com/terms/s/stochasticoscillator.asp
[2014-05-15 15:23:51] |
Yip, so how to I get (H+L)/2 on Sierra?
[2014-05-15 18:20:16] |
Not 100% sure if that is what you want, but if you press F6, double click the stochastics study, and go to the bottom of the input settings window, you can change what input data is being used for the high, low, and close figures. Change these how you like.
[2014-05-15 18:48:29] |
Thanks vegasfoster
