Date/Time: Mon, 29 Apr 2024 06:19:42 +0000
Alerts using Volume value Area line study
View Count: 1577
[2014-05-15 00:56:05] |
Willson - Posts: 176 |
Using the Study "Volume value area lines", how to construct alert when price crosses VAH, VPOC, VAL lines? Want this to work regardless of the setting for percent volume setting (normally %70). regards |
[2014-05-15 17:32:06] |
This can be done by using the CROSSOVER function in a Simple Study Alert formula. Examples can be found at the bottom of this page here: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-15 17:32:34
