Date/Time: Fri, 26 Apr 2024 04:25:25 +0000
Chart menu missing
View Count: 362
[2022-08-31 16:49:23] |
User648702 - Posts: 48 |
My chart is not displaying the chart menu. (edit/chart/analysis/tools etc) at the top. I have tried to help myself but can't find out how get it back. I have looked at every tab in the chart menu and the closest thing is the display tab that lists the title bar name. I right click at the top of the chart and it just brings up a list for trade items on the left and other things on the right including chart. |
[2022-08-31 17:05:00] |
Sierra_Chart Engineering - Posts: 14092 |
Is this a detached chart? Not part of the main Sierra Chart window?
[2022-09-07 15:57:23] |
Yes it is a detached chart
[2022-09-07 16:48:19] |
Attach that Chartbook by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-08 17:50:19] |
I believe I attached the chartbook corectly?
S & P Micro.Cht - Attached On 2022-09-08 17:48:40 UTC - Size: 262.14 KB - 86 views |
[2022-09-22 13:12:04] |
Waiting for response.
[2022-09-22 15:48:25] |
John - SC Support - Posts: 31131 |
Refer to the information at the following link - in particular the paragraph just after the green highlighted one: Chart Menu: Show Menu (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-04 13:06:02] |
I will try that. Have you ever thought about putting lists like available menu item choices in alphabetical order. It would be logical when you have around 100 choices in a menu. Same goes with dom lists etc.
[2022-10-04 13:08:25] |
That worked.....thank you
