Date/Time: Mon, 06 Feb 2023 06:09:19 +0000
[Programming Help] - Assistance with converting study alert code to acsil
View Count: 326
[2022-08-28 18:56:31] |
Ticks - Posts: 109 |
I need some assistance to convert this study alert code found at the link below into ACSIL for use in a strat. Renko Bar Charts: Renko Reversal Bar Alert Formula For bullish:
if (place converted code )//AND(ID0.SG23[-1] > ID0.SG22[-1] , ID0.SG23 < ID0.SG22) { } For bearish:
if (place converted code )//AND(ID0.SG23[-1] < ID0.SG22[-1] , ID0.SG23 > ID0.SG22) { } Or if anyone has and is willing to share the ACSIL code to detecting the reversal bar on a Renko chart. Date Time Of Last Edit: 2022-08-29 00:18:48
[2022-09-04 23:33:44] |
Well, it's been a week with 45 views and still no sample code or suggestions. This must be way harder to convert than I thought. I guess even the coding experts here are stumped on this one. |
[2022-09-05 07:10:59] |
User431178 - Posts: 198 |
Assuming you are using autoloop For bullish:
if (sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index] > sc.BaseDataIn[SC_RENKO_OPEN][sc.Index] && sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index - 1] < sc.BaseDataIn[SC_RENKO_OPEN][sc.Index -1]) { } For bearish:
if (sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index] < sc.BaseDataIn[SC_RENKO_OPEN][sc.Index] && sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index - 1] > sc.BaseDataIn[SC_RENKO_OPEN][sc.Index -1]) { } or you maybe you could use sc.FormattedEvaluate() For bullish:
if (sc.FormattedEvaluate(sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index], sc.BaseGraphValueFormat, GREATER_OPERATOR, sc.BaseDataIn[SC_RENKO_OPEN][sc.Index], sc.BaseGraphValueFormat) && sc.FormattedEvaluate(sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index - 1], sc.BaseGraphValueFormat, LESS_OPERATOR, sc.BaseDataIn[SC_RENKO_OPEN][sc.Index - 1], sc.BaseGraphValueFormat)) { } For bearish:
if (sc.FormattedEvaluate(sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index], sc.BaseGraphValueFormat, LESS_OPERATOR, sc.BaseDataIn[SC_RENKO_OPEN][sc.Index], sc.BaseGraphValueFormat) && sc.FormattedEvaluate(sc.BaseDataIn[SC_RENKO_CLOSE][sc.Index - 1], sc.BaseGraphValueFormat, GREATER_OPERATOR, sc.BaseDataIn[SC_RENKO_OPEN][sc.Index - 1], sc.BaseGraphValueFormat)) { } |
[2022-09-05 14:08:13] |
@User431178 Thanks for the code posting. I tried both of your methods and the code still steps inside the If statement on every tick. Not when the Renko reversal bar closes. I even tried adding in && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED with no success. I'm building with SC and debugging the cpp file with VS. |
[2022-09-05 14:29:09] |
User907968 - Posts: 738 |
SCSFExport scsf_RenkoReversal(SCStudyInterfaceRef sc)
{ auto& sg_RevBuy = sc.Subgraph[0]; auto& sg_RevSell = sc.Subgraph[1]; if (sc.SetDefaults) { sc.GraphName = "Renko Reversal"; sc.GraphRegion = 0; sc.AutoLoop = 0; sg_RevBuy.Name = "Renko Buy Reversal"; sg_RevBuy.DrawStyle = DRAWSTYLE_ARROW_UP; sg_RevBuy.LineWidth = 5; sg_RevBuy.PrimaryColor = COLOR_GREEN; sg_RevSell.Name = "Renko Sell Reversal"; sg_RevSell.DrawStyle = DRAWSTYLE_ARROW_DOWN; sg_RevSell.LineWidth = 5; sg_RevSell.PrimaryColor = COLOR_RED; return; } for (auto index = sc.UpdateStartIndex; index < sc.ArraySize; ++index) { if (sc.GetBarHasClosedStatus(index) != BHCS_BAR_HAS_CLOSED) continue; if (sc.BaseDataIn[SC_RENKO_CLOSE][index] > sc.BaseDataIn[SC_RENKO_OPEN][index] && sc.BaseDataIn[SC_RENKO_CLOSE][index - 1] < sc.BaseDataIn[SC_RENKO_OPEN][index - 1]) { sg_RevBuy[index] = sc.Low[index] - 5 * sc.TickSize; sg_RevSell[index] = 0.0f; } if (sc.BaseDataIn[SC_RENKO_CLOSE][index] < sc.BaseDataIn[SC_RENKO_OPEN][index] && sc.BaseDataIn[SC_RENKO_CLOSE][index - 1] > sc.BaseDataIn[SC_RENKO_OPEN][index - 1]) { sg_RevSell[index] = sc.High[index] + 5 * sc.TickSize; sg_RevBuy[index] = 0.0f; } } } Try the above code. Date Time Of Last Edit: 2022-09-05 14:30:57
[2022-09-05 14:50:40] |
@User907968 That worked. Thank you so much for the study code. I had been working on this for weeks before finally admitting defeat and asking for help. Too bad the board doesn't have a "Tip Jar" feature. To pay it forward. I attached your study code into a .cpp for future people needing help. Date Time Of Last Edit: 2022-09-05 14:59:54
[2022-09-06 23:39:36] |
OctoPi - Posts: 12 |
I believe you may get your coding needs solved in 15-20 minutes instead of weeks with our software. Check it out, we are still looking for a few beta testers. https://www.sierrachart.com/SupportBoard.php?ThreadID=76957 |
[2022-09-30 18:44:14] |
User600819 - Posts: 40 |
@TICKS I have zero experience with cpp files. I tried to compile your cpp file, but I received an error message. Would it be possible to post the dll version? Thanks for your paying it forward! |
[2022-09-30 23:35:13] |
@User600819 Do not use "Remote Build" to compile the cpp file. I have attached the dll. It is compiled with version 2431. If you have a version below that, you may have to complete the cpp compile with your version. A screenshot of the study indicator is attached also. Date Time Of Last Edit: 2022-10-01 01:30:46
[2022-10-01 00:10:13] |
Infinite - Posts: 130 |
TICKS could u share the dll with me or an actual CPP file that will compile. |
[2022-10-01 00:22:41] |
@Infinite The dll is attached in post 9 If the cpp file I have also provided in post 6 does not compile for you. You can use the code that User907968 posted, to create your own cpp file and compile it with your version of SC. I have provided the compiled dll and the cpp that I used. There is really not much else I can provide. |
