Date/Time: Thu, 19 Nov 2026 11:16:58 +0000
Best bid/ask not highlighted in recent bid/ask volume when no number already there.
View Count: 1322
[2022-08-26 08:27:10]
User392433 - Posts: 44
On the trade dom, the best bid/ask is not getting highlighted in the recent bid/ask volume columns when there is not already a number there. I read this thread that says it is fixed: Problem with Trade DOM Setting Recent Bid/Ask Best Bid/Ask Background and I have the latest version (prerelease) installed, but am still getting this issue. Is there a fix for this?
Date Time Of Last Edit: 2022-08-26 10:58:16
[2022-08-26 10:59:14]
That thread is very old and would not be relevant.
We are not really sure what you are referring to.
Provide an image of the Chart/Trade DOM:
Date Time Of Last Edit: 2022-08-26 10:59:26
[2022-08-26 16:31:12]
Image without best bid/ask highlighted with no numbers in bid/ask volume column. (Unexpected Behavior)
https://www.sierrachart.com/image.php?Image=1661530855888.png
Image with best bid/ask highlighted along with recent bid/ask last trade. (Expected behavior)
https://www.sierrachart.com/image.php?Image=1661530891855.png
Image with best bid/ask highlighted where recent bid/ask last trade overrides the best bid. (Expected Behavior)
https://www.sierrachart.com/image.php?Image=1661530914261.png
For my settings I set the "Recent Bid Best Bid Background" and "Recent Ask Best Ask Background" highlight to be white. The Last Traded Recent Bid Volume Background is a red color. The Last Traded Recent Ask Volume Background is green. These are all for the Trade Dom. I noticed that when there is not a number in the Recent Bid/Ask Volume column, then the square with the best bid and ask is not highlighted. This can be when there are no numbers in both bid and ask square or just one. However, when there are numbers already in it, then it works as expected.
[2022-08-29 09:04:29]
Yes this does make sense:
[2022-08-29 14:06:20]
In jigsaw it highlights regardless. And it seems this from the earlier post this was the intended functionality too.
If it wasn't made to be like this how do I request this feature to be added?
[2022-08-29 14:37:47]
You just did make the request to add the feature.
[2024-12-09 07:28:36]
genchev.finance - Posts: 22
Hello :).
I do have the exact sane issue.
Best bid/ask on the recent columns is highlighted only when there is a number in it.
Has the problem been resolved?
Date Time Of Last Edit: 2024-12-09 07:29:00
