Date/Time: Tue, 07 May 2024 02:35:05 +0000
VbP request
View Count: 1484
[2014-05-13 17:53:31] |
joshtrader - Posts: 439 |
Currently the "outline only" mode of VbP yields a picture like this: http://screencast.com/t/kRSmT9Ck The problem of course, is that there is a sloping line along the whole gap, when in fact a more visually accurate picture would have a vertical line. So, my request is to implement the "outline only" mode of VbP as a stair step, instead of a line. Or, at least provide the option. If you would like to see an example of this from another program that uses this method I can post it but I think you understand. This is not useful for gaps only--it is a very nice way to view all profiles that have outlines only. Date Time Of Last Edit: 2014-05-13 17:54:12
[2014-05-14 17:10:39] |
We will see about this.
[2014-05-15 01:48:08] |
We will be looking into this.
[2014-05-15 13:45:00] |
Al SC Developer - Posts: 434 |
In ver 1139, this is changed to not draw across zero volume levels in outline mode
