Date/Time: Wed, 04 Nov 2026 20:28:48 +0000
Count Down Timer
View Count: 752
| [2022-08-17 14:14:39] |
| six steps - Posts: 47 |
Hello, I have added a count down timer to my 30, 15, and 5 min chart. My 15 min displays No No No... across the top. How do remove that message while still keep my timer? Thanks, |
| [2022-08-17 15:10:57] |
| John - SC Support - Posts: 48429 |
The only reason that information is showing for one chart and not for another is because there are other studies on the other chart that takes up all the space, so you are just not seeing it, otherwise it would be there too. But, in order to not display that information, you need to deselect the options for Display Study Name and Display Input Values on the Subgraph tab of the study settings window. Refer to the information at the following link and the section after it: Chart Studies: Subgraphs Tab >> Display Study Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
