Date/Time: Sat, 04 May 2024 08:02:09 +0000
one candle
View Count: 934
[2014-05-12 13:05:56] |
Carol Rutherford - Posts: 66 |
I am setting up a new system and when I open a nyse-i-nyse daily chart I only get one candle. How do i get back candles like show up on my other daily charts.
[2014-05-12 16:46:04] |
We have looked this up. This does not look like a valid index, at least from what we can tell. What specific index do you want? Do you want the NYSE composite index?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 16:46:33
[2014-05-12 17:24:49] |
sorry symbol I typed in is indu-I-nyse Have one candle in Daily chart and some candles are showing in the 13 minute |
[2014-05-12 17:28:04] |
Make sure you have the correct symbol settings. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this, open a new chart for INDU-I-NYSE through the File >> Find Symbol window. Be sure to use that window. It will be listed in the Indexes section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 17:28:43
