Date/Time: Fri, 03 May 2024 16:06:09 +0000
Sierra Chart /CQG can't see the Quote and market depth
View Count: 1553
[2014-05-12 12:06:17] |
CaseyWang - Posts: 13 |
Dear sir, If I use the CQG fee,could I see the Quote and market depth?! Because I could not see the Quote and market depth now. |
[2014-05-12 15:57:34] |
You can receive market depth and real-time quote data from CQG. However, you need to make sure you are enabled for market data from the CQG system and you have entered the Username and Password in Sierra Chart for the market data connection. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/CQGTrading.php#SetupInstructions Also, make sure Sierra Chart is up-to-date. Select Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-15 13:32:30] |
Dear support, I still can not see the market depth and real-time quote data from CQG. Could you help me check this issue?! email address:87xxxxxx(hide)@qq.com Screenshot: http://4.bp.blogspot.com/-O2DXSRzZyeI/U3TOy4DILsI/AAAAAAAABu8/cuAL2VkwTvI/s1600/QQ%CD%BC%C6%AC20140515214359.jpg Date Time Of Last Edit: 2014-05-15 16:34:45
[2014-05-15 16:37:10] |
You also need to enter your CQG Username and Password in the Market Data Connection Details frame. This is explained in the set up instructions here: http://www.sierrachart.com/index.php?l=doc/CQGTrading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
